Emails are not delivered occasionally: warning: read TCP map reply from 127.0.0.1:12346: unexpected EOF (Connection timed out)
11 comments
  • As per the following output I have adjusted the script to only get the IPs and remove the `(smtp:`, `(smtps:`, `(submission:` and `)` strings.
    (smtp:1.2.3.4)
    (smtps:2.3.4.5)
    (submission:3.4.5.6)
    # for IP in `grep 'max connection count' /var/log/maillog | awk '{ print $12 }' | sort | uniq | grep -Eo '([0-9]\.?)+'`; do echo -e "Checking IP.. $IP"; egrep "connect .*$IP" /var/log/maillog | awk '{print $6}' | sort | uniq -c ; done
    1
    Robert Valdés
    Yes! a lot
    Nov 26 03:56:53 s3 postfix/spawn[5033]: warning: /usr/lib64/plesk-9.0/postfix-srs: process id 5043: command time limit exceeded
    Nov 26 03:56:53 s3 postfix/spawn[5052]: warning: /usr/lib64/plesk-9.0/postfix-srs: process id 5054: command time limit exceeded
    Nov 26 03:56:53 s3 postfix/spawn[5056]: warning: /usr/lib64/plesk-9.0/postfix-srs: process id 5057: command time limit exceeded
    Alisa Kasyanova
    @John
    Then it is needed to investigate the issue thoroughly. Please submit a support request using your available option.
    Alexandr Redikultsev
    Then let me provide you with some tips on how to troubleshoot this issue. Basically in can occur in case there is one IP that connects to the server and then does not close the connection for some reason.
    1. Find all 'max connection count' in the maillog, it should looks like the example below:
    # grep 'max connection count' /var/log/maillog | tail -n 2
    postfix/anvil[28023]: statistics: max connection count 34 for (smtp:203.0.113.2 ) at Sep 3 11:47:48
    postfix/anvil[51714]: statistics: max connection count 11 for (smtp:203.0.113.2 ) at Sep 3 12:25:57
    In this example, there are 34 and 11 connections from 203.0.113.2 .
    2. Then, check this IP with the netstat in order to understand whether or not there are some hanging connections:
    # netstat -tulnap | grep 203.0.113.2 | wc -l
    23
    # netstat -tulnap | grep 203.0.113.2 | head -n 2
    tcp 0 1 203.0.113.10:25 203.0.113.2:49701 FIN_WAIT1 -
    tcp 0 1 203.0.113.10:25 203.0.113.2:49784 FIN_WAIT1 -
    3. Now it's time to check Connect/Disconnect ratio from offending IP:
    This is the normal output (connect matches disconnect):
    # grep 'connect .*203.0.113.2' /var/log/maillog | awk '{print $6}' | sort | uniq -c
    603 connect
    603 disconnect
    This is not correct output:
    86 connect
    20 disconnect
    4. In theory, the following script is intended to provide IPs addresses connection ratio statistics:
    # for IP in `grep 'max connection count' /var/log/maillog | awk '{ print $12 }' | sort | uniq | sed 's/(smtp://g; s/)//g;'`; do echo -e "Checking IP.. $IP"; egrep "connect .*$IP" /var/log/maillog | awk '{print $6}' | sort | uniq -c ; done
    Overall in case on step 3 you are getting connect/disconnect ratio mismatch, this means that host 203.0.113.2  does not close the connection and is causing the issue. Solution would be to either ban this IP address or contact them somehow letting them know that their mail client is malfunctioning.
    As a workaround, it should be also possible to increase number of connection from one IP address at Tools & Settings > Mail Server Settings.
    John MacKenzie
    My server just started getting this error.
    Restarting the service seems to get it stable for 5 minutes or so.
    The output matches the above. Adding the -s as stated in the turning off SRS thread has no impact on whether it occurs or not.
    Any other suggestions?
    John MacKenzie
    Yes CentOS , SElinux is diabled
    Ivan Postnikov
    Hello Reynaldo Abimael Aceves Chamosa
    Thank you for sharing =)
    Robert Valdés
    Ok thanks, I try to activate fail2ban
    Robert Valdés
    I Have the same problem.
    Configuration OK
    grep postfix-srs /etc/postfix/master.cf
    127.0.0.1:12346 inet n n n - - spawn user=popuser:popuser argv=/usr/lib64/plesk-9.0/postfix-srs
    Selinux disabled
    sestatus
    SELinux status: disabled
    Maillog
    Nov 20 15:48:42 s3 postfix/smtpd[19836]: warning: read TCP map reply from 127.0.0.1:12346: unexpected EOF (Connection timed out)
    Nov 20 15:48:42 s3 postfix/smtpd[19836]: warning: tcp:127.0.0.1:12346 lookup error for "mymail@mydomain.com"
    Hi @Robert,
    Are there any messages like the one below in the maillog as well?
    warning: /usr/lib64/plesk-9.0/postfix-srs: process id #####: command time limit exceeded
