Starting on October 19, 2021, we will enable single-sign-on for our Plesk Support Center to provide a seamless login/account experience. This implies that you’ll be able to use a single account across any of our web-facing properties.
To be prepared for this change and to avoid the need to register during your next ticket submission after the change, we encourage you to create an account here before October 19 using the same email address as your current Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account. You will continue to use ZenDesk authentication until we switch over to single-sign-on on October 19th.
Domains periodically unavailable for some time: (111: Connection refused) while connecting to upstream
3 comments
    Andy Little
    It looks like it was Fail2ban adding my server IP that caused this issue for me. I tried the steps in this article but httpd would not restart. I had to run Plesk Repair to fix it.
    Hope this helps someone else!
    Ivan Postnikov
    Hello @Andy,
    Thank you for sharing.
    It may be helpful to other Pleskians.
    Claus Siebeneicher
    Had 502 Bad Gateway and this nginx error in the logs:
    671#0: *1 connect() failed (111: Connection refused) while connecting to upstream
    Serving IPV4 and V6 and fail2ban running. Restarting fail2ban and setting the own IPs as trusted IP solved the issue.
