Plesk for Linux
kb: how-to
ABT: Group B
How to manage PHP max_input_vars
variable on Plesk for Linux?
For a single domain
Go to Domains > example.com > PHP Settings
Add the max_input_vars variable in the Additional configuration directives field and click OK to apply the changes:
CONFIG_TEXT: max_input_vars = 3000
For particular PHP version
- Log in to Plesk GUI
- Go to Tools & Settings > PHP Settings > Click on the required PHP version. For example, PHP 7.4 FPM:
- Switch to the php.ini tab:
- Remove the semicolon symbol
beforemax_input_vars
parameter, set the desired value and click OK to apply the changes:
3 comments
The Additional configuration directives field is not available with the Power User View, you need use the Service Provider view
I did as described, upped max_input_vars to 3000, while only 2000 is needed. Prestashop still gives me notifications about needing to up that value to 2000. Does PHP need to be restarted after such a change?
Not working, limit is 2000
