- External firewall is used.
- Secure FTP connection is not working in Plesk if external firewall is used:
CONFIG_TEXT: 425 Unable to build data connection: Connection timed out
ORCONFIG_TEXT: Timeout detected. (data connection) Could not retrieve directory listing Error listing directory '/'.
- nf_conntrack_ftp module is loaded and it is possible to connect to the server via FTP in passive mode if non secure connection is used:
# lsmod | grep ftp
nf_conntrack_ftp 18638 0
nf_conntrack 133053 6 nf_nat,nf_nat_ipv4,xt_conntrack,nf_conntrack_ftp,nf_conntrack_ipv4,nf_conntrack_ipv6
When secure FTP connection is used nf_conntrack_ftp is not working.
External firewall can not open ports because information that FTP server passes to the client is encrypted.
- Open needed passive port range in external firewall
Open the file
/etc/proftpd.conf
in any text editor and place the content below to theGlobal
section as follows:<Global>
PassivePorts 49152 65535
</Global>Note: Starting from Plesk Onyx, passive ports can be defined in
/etc/proftpd.d/55-passive-ports.conf
file. - Restart xinetd service to apply changes:
# service xinetd restart
