Roundcube takes a lot of time to access the mailbox.
The following error can be found in
/var/log/plesk-roundcube/errors
:CONFIG_TEXT: [11-May-2018 03:07:04 UTC] PHP Warning: fgets(): SSL read operation timed out in /usr/share/psa-roundcube/program/lib/Roundcube/rcube_imap_generic.php on line 204
/var/log/maillog
:CONFIG_TEXT: May 11 03:07:04 server dovecot: service=imap, user=jdoe@example.com, ip=[::1]. Connection closed (UID FETCH finished 60.114 secs ago) rcvd=459, sent=61956
System PHP version is 5.6 or lower:
# php -v | grep cli
PHP 5.6.33-0+deb8u1 (cli) (built: Jan 5 2018 15:46:26)
Insufficient Roundcube performance on older PHP versions.
Switch Roundcube to a newer PHP version shipped by Plesk. For example, 7.0:
Make sure that required PHP handler is installed:
# plesk bin php_handler --list | grep fast | awk {'print $1'}
fastcgi
plesk-php56-fastcgi
plesk-php70-fastcgi
plesk-php71-fastcgi
plesk-php72-fastcgiIf not, refer to the this article to install additional PHP version.
Create a custom template file and redefine PHP handler for Roundcube there:
# mkdir -p /opt/psa/admin/conf/templates/custom/webmail/
# cp -p /opt/psa/admin/conf/templates/default/webmail/roundcube.php /opt/psa/admin/conf/templates/custom/webmail/
# sed -i 's/fastcgi/plesk-php70-fastcgi/g' /opt/psa/admin/conf/templates/custom/webmail/roundcube.php -
Regenerate web server configuration files:
# /opt/psa/admin/bin/httpdmng --reconfigure-all
