A custom script is set up as a scheduled task at Tools & Settings > Scheduled Tasks.
The script contains one or both of following commands:
CONFIG_TEXT: /etc/init.d/example start
/etc/init.d/example stop -
The task is shown as running in Plesk even though it has completed.
Such behavior is confirmed as a Plesk bug with ID PPPM-8527.
As a workaround, use systemctl commands in the script:
CONFIG_TEXT: systemctl start example.service
systemctl stop example.service
instead of
