Plesk for Windows
kb: bug
ABT: Group A
- Plesk for Windows
Upgrade started in Web UI (Tools & Settings > Updates and Upgrades) gets stuck:
CONFIG_TEXT: Installation started in background
Installing packages
Installing MySQL 5.7 server...
Configuring MySQL 5.7 server...
Bug with ID #PPPM-8507 which will be fixed in future Plesk versions
As a workaround, use the console version of Plesk Installer. To do so:
Connect to the server via RDP;
- Kill all Plesk Installer processes in Task Manager:
Launch the following command in CMD:
C:\> plesk installer --console
