Starting on October 19, 2021, we will enable single-sign-on for our Plesk Support Center to provide a seamless login/account experience. This implies that you’ll be able to use a single account across any of our web-facing properties.
To be prepared for this change and to avoid the need to register during your next ticket submission after the change, we encourage you to create an account here before October 19 using the same email address as your current Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account. You will continue to use ZenDesk authentication until we switch over to single-sign-on on October 19th.
Plesk interface is not accessible on ports 8443/8880: ERR_CONNECTION_TIMED_OUT
2 comments
    Franz Bludorf
    I followed all the steps described here, but it didn't help. See the terminal protocol of the steps on my server:
    root@h2632858:~# iptables -nL | grep 8443
    root@h2632858:~# iptables -I INPUT 1 -p tcp --dport=8443 -j ACCEPT
    root@h2632858:~# iptables -I INPUT 1 -p tcp --dport=8880 -j ACCEPT
    root@h2632858:~#
    # prepare firewall management
    /usr/local/psa/bin/modules/firewall/settings -e
    Firewall rules management was successfully enabled, use --confirm command within 60 second(s) to confirm enable, otherwise firewall rules management will be disable.
    root@h2632858:~# exit
    Abgemeldet
    Connection to h2632858.stratoserver.net closed.
    franz@UbuntuDesktop:~$ sudo ssh root@h2632858.stratoserver.net
    root@h2632858.stratoserver.net's password:
    Welcome to Ubuntu 18.04.5 LTS (GNU/Linux 4.15.0 x86_64)
    * Documentation: https://help.ubuntu.com
    * Management: https://landscape.canonical.com
    * Support: https://ubuntu.com/advantage
    Last login: Wed Mar 24 08:09:25 2021 from 95.49.208.201
    This server is powered by Plesk.
    Run the 'plesk login' command and log in by browsing either of the links received in the output.
    Use the 'plesk' command to manage the server. Run 'plesk help' for more info.
    root@h2632858:~# /usr/local/psa/bin/modules/firewall/settings -c
    psa-firewall.service is not a native service, redirecting to systemd-sysv-install.
    Executing: /lib/systemd/systemd-sysv-install enable psa-firewall
    Firewall rules management was successfully confirmed.
    root@h2632858:~#
    # define firewall rules
    /usr/local/psa/bin/modules/firewall/settings -s -name 'Plesk' -direction input -action allow -ports '8443/tcp,8880/tcp'
    Firewall rule was successfully created; rule id: '45'.
    root@h2632858:~# /usr/local/psa/bin/modules/firewall/settings -a
    Firewall rules were successfully activated, use --confirm command within 60 second(s) to confirm activation, otherwise all changes will be rolled back.
    Abgemeldet
    Last login: Wed Mar 24 08:17:56 2021 from 95.49.208.201
    root@h2632858:~# /usr/local/psa/bin/modules/firewall/settings --confirm
    Firewall rules were successfully confirmed.
    root@h2632858:~#
    # Check if port 8443 is free
    ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:8443
    root@h2632858:~# plesk login
    https://www.fosar-bludorf.com:8443/login?secret=AglblFAVR0tSQsjjhbxYQ1jTsBJge5flpzsanPAQtTtSevG2
    root@h2632858:~#
    After that, the https address given above doesn't work:
    Windows network error management resulted in a message, that the page is online, is accessible on the webserver, but there is no response:
    Any suggestion what I did wrong? Any ideas what I could try next?
    Shakeel Shahid
    Dear Team,
    I am using Plesk application in my organization but the issue is I am not able to open the portal on port 8443. however I have disabled the server firewall and able to telnet the port from the localhost but from other machine which is one the same network I am not. kindly help me in the same.
