Unable to restore a multi-volume (incremental) backup: invalid compressed data--format violated
2 comments
    Kevin
    Using the patched deployer (2018-04-29) the error message is now:
    Perhaps /opt/psa/admin/bin/deployer application missing, has incorrect permissions or unexpectedly terminated
    Deployer is at said location, calling the deployer directly:
    ./deployer: error while loading shared libraries: libjson-c.so.2: cannot open shared object file: No such file or directory
    System: Debian 9.4, Plesk 17.8.11 Update #6
    1
    Alexandr Redikultsev
    Hello, Kevin!
    Thank you for noticing it! The file in the article was applicable for Plesk 12.5 on CentOS 7 only.
    I have updated it with the file for Plesk 17.8 on Debian 9.
    Also, you can check the following article in case the issue with the restore will persist:
    Some files can not be restored from a backup: Unexpected EOF in archive
