Is it possible to enable Argon2 PHP module in Plesk?
4 comments
    Stéphan Schamp
    You can use Argon2, which isn't a PHP module but rather an extension of the password_* functions.
    You can install PHP 7.2 or 7.3 from https://deb.sury.org/ which has Argon2 support compiled in to PHP.
    And then register this as a new PHP handler in Plesk.
    Alisa Kasyanova
    @Stéphan Schamp
    Thank you for your comment, I am sure it would be helpful to other Plesk users. However, I want to note that such solution was not officially tested by Plesk, so this workaround should be used on own will and risk.
    dasty
    After weeks I succeeded, I put the link of the commands to run on centos to install plesk with php + argon2
    https://github.com/xdasty/plesk-php-argon2
    Ivan Postnikov
    @dasty,
    Thank you, this may be useful for other Pleskians.
