Is it possible to change rotation settings for /var/log/maillog
It is not possible to manage rotation settings for /var/log/maillog
. By design, /var/log/maillog
is rotated every day during Plesk Daily Maintenance task.
As an alternative, /var/log/maillog.proccessed
rotation settings may be changed instead. After Daily Maintenance Task is executed, all log data is moved from /var/log/maillog
to /var/log/maillog.proccessed
To modify /var/log/maillog.proccessed
rotation settings, perform the following steps:
Log in to the server via SSH.
Edit the settings in the
/usr/local/psa/etc/logrotate.conf
file:CONFIG_TEXT: /var/log/maillog.processed {
weekly
missingok
rotate 3
compress
nocreate
Note: Use one of the following words to set the rotation frequency: hourly
, daily
, weekly
, monthly
, yearly
