- Unable to install Plesk with the following error::
PLESK_INFO: Synchronizing state of mysql.service with SysV init with /lib/systemd/systemd-sysv-install...
Executing /lib/systemd/systemd-sysv-install enable mysql
Failed to execute operation: Too many levels of symbolic links - Both MariaDB and MySQL services are running on the server:
# systemctl status mariadb
Active: active (running) since Tue 2018-04-17 00:31:39 CEST; 1min 47s ago
Apr 17 00:31:39 3-lithium mysqld[11431]: Version: '10.3.6-MariaDB-1:10.3.6+maria~xenial-log' socket: '/var/run/mysqld/mysqld.sock' port: 3306 mariadb.org binary distribution# systemctl status mysqld
Active: active (running) since Tue 2018-04-17 00:31:39 CEST; 2min 9s ago
Apr 17 00:31:39 3-lithium mysqld[11431]: Version: '10.3.6-MariaDB-1:10.3.6+maria~xenial-log' socket: '/var/run/mysqld/mysqld.sock' port: 3306 mariadb.org binary distribution - As can be seen from the output of the commands above services are using the same binary file of MariaDB:
CONFIG_TEXT: 10.3.6-MariaDB-1:10.3.6+maria~xenial-log' socket: '/var/run/mysqld/mysqld.sock' port: 3306 mariadb.org binary distribution
MariaDB and MySQL services are using the same MariaDB binary file.
- Log into the server via SSH.
Note: If direct SSH access to the server is not possible, contact server administrator for further assistance.
- Stop MariaDB service:
# systemctl stop mariadb
Disable MariaDB service:
# systemctl disable mariadb
Delete existing symlinks of MariaDB and MySQL services:
# rm /etc/systemd/system/mariadb.service
Enable MariaDB service:
# systemctl enable MariaDB:
Start Mariadb:
# systemctl start mariadb
