The installed Plesk version is less than 12.0.
Using the
plesk
command leads to the following error:# plesk db
-bash: plesk: command not found
The plesk
command was introduced in Plesk 12.0 and it is detected as unknown in all older versions of the product.
Upgrade Plesk to at least 12.0.
