How to secure webmail.example.com when example.com is hosted on a different server?
9 comments
    Lok Ming Chu (Edited )
    The "Use Let's Encrypt certificate" part is not update
    "FcgidInitialEnv PP_CUSTOM_PHP_CGI_INDEX fastcgi" need change to "FcgidInitialEnv PP_CUSTOM_PHP_CGI_INDEX plesk-php73-fastcgi"
    ===== My Plesk version =====
    Plesk Obsidian
    Version 18.0.20, last updated on Oct 29, 2019 11:00 PM
    Nick Bucko
    How am I supposed to use a Let's Encrypt Wildcard on the server that is just hosting mail?  Since the site is not hosted on the server hosting mail the LE file validation will fail.
    Nick Bucko
    I followed the second option, creating a webmail subdomain and it now I get an internal server error for webmail and I can't turn webmail back on under the primary domain because there is a subdomain with the name webmail.xxxx.com.  These workarounds don't seem to work at all.
    Ivan Postnikov
    Hello @Nick,
    There're plans to add functionality to assign TLS Certificate to Webmail on a domain without hosting.
    As for the issue, you currently have, please, submit a request for Plesk Support, additional investigation is required. If the license was bought from us directly, the request may be submitted to us. If it was purchased from our partner, submit a request to them.
    Bulat Tsydenov
    @Lok Ming Chu
    I agree with you because starting from Plesk Obsidian PHP by OS vendor my be not installed at all. The article will be modified accordingly.
    Alexander Koch (Edited )
    As a workround for roundcube:
    1. Copy /usr/local/psa/admin/conf/templates/default/webmail/roundcube.php -> /usr/local/psa/admin/conf/templates/custom/webmail/roundcube.php
    2. Edit the custom roundcube.php -> Append following Line under Alias /roundcube/ :
    Alias /.well-known/acme-challenge "/var/www/vhosts/default/htdocs/.well-known/acme-challenge"
    3. plesk sbin httpdmng --reconfigure-all
    4. Add Subdomain webmail.domain.tld
    5. Secure this Subdomain with Let`s Encrypt
    6. Click SSL on the Maindomain, click Advanced Settings and secure webmail with the certificate from the Subdomain
    And thats all, i hope this helps.
    Greetz Alex
    1
    Ivan Postnikov
    Hello Alexander Koch
    Thank you for the suggestion, it may be useful for other Pleskians.
    Alex Laforge
    The workaround posted by Alexander Koch on  January 23, 2020 is only applicable for Linux, not Windows. How can we do for Windows ?
    I managed securing webmail.domain.tld by creating the subdomain "webmail", issuing a certificate for it, then deleting this subdomain,  and use the previously generated certificate to secure the Webmail.
    But this will only work for 3 months, and certificate will not be renewed automatically !
    WOuld you please update your workaround to be applicable to Windows !? Thank you very much... We can't wait any longer for a working workaround. (and Yes, I voted on Uservoice.. this is opened since 2017 such a shame for the dev team)
    Anton Maslov
    Hello Alex. At this moment the only available workaround for Windows is to purchase SSL certificate from the 3rd party.
