- Plesk Onyx 17.5 for Linux
After adding IP addresses, some of them are missing in the interface file.
Missing addresses, as well as some existing ones, are shown in Tools & Settings > IP Addresses as broken.
Repair button does not resolve the error.
Around 600 addresses are added to one interface.
Plesk bug #PPPM-8260 which is planned to be fixed in future product updates.
Until the bug is fixed, the following workaround can be used for Plesk Onyx 17.5 on RHEL 7/CentOS 7/CloudLinux 7:
Download and unpack attached fix:
# wget https://plesk.zendesk.com/hc/article_attachments/360003173854/ifmng.zip && unzip ifmng.zip
Backup the original file and replace it with the patched one:
# mv /usr/local/psa/admin/sbin/ifmng /usr/local/psa/admin/sbin/ifmng.orig && cp ifmng /usr/local/psa/admin/sbin/ifmng && chmod 750 /usr/local/psa/admin/sbin/ifmng
Repair broken IP addresses via Plesk interface.
