- Plesk for Windows
The following notification is received:
CONFIG_TEXT: Limit has been exceeded on domain 'example.com'
but no limitations are set for this domain in it's service plan (Service Plans > <service plan to which domain is assigned to> Resources).
In Tool & Settings > Action log, the following is shown for the example.com:
CONFIG_TEXT: 'MSSQL database soft quota reached' ('Microsoft SQL database quota': '' => '178257920', 'Microsoft SQL Database Usage': '' => '191234048', 'Domain Name': 'example.com'
MSSQL database soft quota reached. By default, it is 85% from the overall limit, so in case the limit is 200 MB, notification is sent when database size > 170MB.
Increase the limit for the MSSQL quota, or adjust the notification limit:
The soft limit can be changed in panel.ini
To correct it, do the following:
- Log into Plesk;
- Open
panel.ini
file using Panel.ini editor extension; - Specify the option databaseManagement.diskSpaceSoftQuota. The value is the percentage of the limit (default is 85%). For example:
CONFIG_TEXT: [databaseManagement]
diskSpaceSoftQuota=50
Additional Information
Administrator's Guide: Event Parameters
