Enabling HTTP/2 in Advisor extension does not work on Plesk server
7 comments
    Barbara Muster
     Tried the work around.. but this also does not work :(
    Plesk keeps disabling http2
    When will you fix this error?
    Ivan Postnikov
    @Barbara, currently the exact ETA for the bug resolution is not available.
    However, as it is stated in the article, this is a cosmetic bug and can be safely ignored.
    djyoungster32
    agree with Barbara Muster Plesk keeps disabling http2
    Ivan Postnikov
    Hello @djyoungster32,
    What version of Advisor extension is used? The article is updated and the issue should have been resolved in version 1.3.0 of extension.
    djyoungster32
    Advisor extension is Version: 1.3.2-178
    Barbara Muster
    For me its Version: 1.3.2-178
    Alexandr Nikolaenko
    Hello @djyoungster32, @Barbara Muster,
    A have rechecked and clarified, that bug is still in work. A bugfix notification will be removed from the article in nearest future.
    Meanwhile, you can use provided workaround.
