Enabling HTTP/2 in Advisor extension does not work on Plesk server
11 comments
    Barbara Muster
     Tried the work around.. but this also does not work :(
    Plesk keeps disabling http2
    When will you fix this error?
    Ivan Postnikov
    @Barbara, currently the exact ETA for the bug resolution is not available.
    However, as it is stated in the article, this is a cosmetic bug and can be safely ignored.
    djyoungster32
    agree with Barbara Muster Plesk keeps disabling http2
    Ivan Postnikov
    Hello @djyoungster32,
    What version of Advisor extension is used? The article is updated and the issue should have been resolved in version 1.3.0 of extension.
    djyoungster32
    Advisor extension is Version: 1.3.2-178
    Barbara Muster
    For me its Version: 1.3.2-178
    Alexandr Nikolaenko
    Hello @djyoungster32, @Barbara Muster,
    A have rechecked and clarified, that bug is still in work. A bugfix notification will be removed from the article in nearest future.
    Meanwhile, you can use provided workaround.
    Lucaele
    Hi all,
    are there any news for this bug?
    Thanks!
    Luca
    Ekaterina Babenko
    Hello Luca,
    Currently there is no ETA for bug fix.
    Information will be removed from Release notes shortly. I have already updated the article.
    Please, subscribe to it in order to be notified about bug fix.
    Mitchell van Bijleveld
    Even though this is just a cosmetic bug, as a paid user I expect those small things to be fixed as soon as possible, and if the first reply to this bug is more than one year ago, I am very disappointed.
    Anton Maslov
    @Mitchell
    Basically there are two reasons why it still not fixed:
    1. Bug is just cosmetic one and has no impact
    2. Bug occurs only with specific conditions and affect very small amount of users, those who have "ssl.protocols" configured in panel.ini
    That's why it has "low" priority.
