How to speed up a Plesk migration?
4 comments
    Unknown User
    Plesk onyx restore is very slow than before. 80 mbs takes around 20 minutes before it used to be 1 or 2 maximum.
    Ivan Postnikov
    Hello @James,
    Such behavior is not typical for Plesk Onyx.
    To investigate the issue consider contacting technical support.
    Sathiya (Edited )
    I have migrated below data it takes 18 hours to complete its really slow even both servers in same network.
    Both server having dedicated 3 MBPS connection speed
    Disk usage 52.7 GB
    Traffic 4.65 GB
    Active domains 130
    Domains 151
    Subdomains 68
    Mailboxes 336
    Forwarders 0
    Mail groups 42
    Auto-replies 7
    Mailing lists 0
    Web users 0
    MySQL databases 64
    MSSQL databases 62
    Alexandr Bashurov
    @Sathiya
    Migration speed may differ based on the many factors, such as the type of data transferred.
    IO operations on small files, for example, tend to be way slower due to the way how file systems work.
