- Plesk for Windows
Plesk is not accessible:
CONFIG_TEXT: HTTP Error 500.0 - Internal Server Error
C:\Program Files (x86)\Plesk\admin\engine\php-cgi.exe - The FastCGI process exited unexpectedly -
If try accessing Plesk directly on the server while connected to it over RDP, the following detailed information is shown:
CONFIG_TEXT: Detailed Error Information:
Module FastCgiModule
Notification ExecuteRequestHandler
Handler PleskEngine-FastCGI-php
Error code 0x00000000
Requested URL https://localhost:8443/index.php
Physical Path C:\Program Files (x86)\Plesk\admin\htdocs\index.php
Logon Method Anonymous
Logon User Anonymous -
The application pool
PleskControlPanel
and the sitepleskcontrolpanel
are started in IIS. -
Repairing Plesk site using Plesk Reconfigurator does not help as well.
PHP which is used for serving Plesk site (located in the directory %plesk_dir%admin\engine
) is corrupted.
Connect to the server using RDP.
Back up the directory
Locate the necessary MSI file which contains Plesk's PHP files.
For example, for Plesk Onyx 17.5.3 this file is
C:\ParallelsInstaller\parallels\PANEL-WIN_17.5.3\dist-msi-Microsoft-2003-i386\plesk-engine_mu028.msi
.Alternatively, the file can be called just
plesk-engine.msi
Create a directory for extracting the files from MSI (for example,
C:\tempMSI
Unpack the MSI file found in step 3:
C:\> msiexec /a C:\ParallelsInstaller\parallels\PANEL-WIN_17.5.3\dist-msi-Microsoft-2003-i386\plesk-engine_mu028.msi /qb TARGETDIR=C:\tempMSI
Copy all files from the directory
C:\tempMSI\Program Files\Parallels\Plesk\admin\engine
to the directory%plesk_dir%admin\engine
with replacing the already existing files.
