Plesk update process fails with the following error message:
CONFIG_TEXT: ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
Trying to start service mysql... failed
server.example.com systemd[1]: mariadb.service: main process exited, code=exited, status=1/FAILURE
server.example.com systemd[1]: Failed to start MariaDB 10.2.13 database server.
server.example.com systemd[1]: Unit mariadb.service entered failed state.
server.example.com systemd[1]: mariadb.service failed. -
MariaDB service cannot be started. The following error message is logged in
/var/log/messages
:CONFIG_TEXT: [ERROR] Aria engine is not enabled or did not start. The Aria engine must be enabled to continue as mysqld was configured with --with-aria-tmp-tables
CONFIG_TEXT: [Note] mysqld: Aria engine: starting recovery
recovered pages: 0% 10% 20% 30% 40% 50% 60% 70% 80%201210 16:07:56 [ERROR] mysqld got signal 11 ;
Unclear.
Shut down MariaDB database server:
# mysqladmin -uadmin -p`cat /etc/psa/.psa.shadow` -h127.0.0.1 --protocol=tcp shutdown
Rename the
aria_log_control
file:# mv /var/lib/mysql/aria_log_control /var/lib/mysql/aria_log_control.orig
Start MariaDB service:
# service mariadb start
Run Plesk Update:
# plesk installer update
