Troubleshooting: Site Audit stuck at 0% progress
4 comments
    William
    How do you shut down  the extra site audits from running so as to fix this?
    Ivan Postnikov
    Hello @William,
    Could you, please, share a bit more information about the issue you have?
    What is used to audit in your case?
    William
    Was the SEO audit jamming
    fixed using this suggestion
    SEO Toolkit scan tasks are stuck
    Ivan Postnikov
    @William, glad to hear that you've found the solution.
