If you had already registered your account at Plesk 360 (formerly known as My Plesk) please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
Connection to MySQL database fails: Specified driver could not be loaded due to system error 5: Access is denied. (MySQL ODBC 5.1 Driver)
3 comments
    Christopher Danks
    step 4 is incorrect as adding > after bin64 would cause an error.  replace > with \ and remove the space.
    Ivan Postnikov
    @Christopher Danks
    Hello!
    Thank you for notice.
    The article was updated.
    esfahanhost
    Hi
    i add only (  Unicode Driver ) in connection string and problem resolved
    Change this :
    Conn.Open "DRIVER={MySQL ODBC 5.3 };SERVER=localhost; DATABASE=psa; UID=admin;PASSWORD=mypassword;Port=8306; OPTION=3"
    To :
    Conn.Open "DRIVER={MySQL ODBC 5.3 Unicode Driver};SERVER=localhost; DATABASE=psa; UID=admin;PASSWORD=mypassword;Port=8306; OPTION=3"
    Best Regards
    Masoud Saeidi
    http://www.esfahanhost.com
