If you had already registered your account at Plesk 360 (formerly known as My Plesk) please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
Site shows: ERR_CONNECTION_TIMED_OUT
1 comment
    Pamela Reynolds
    The resolution script doesn't work - says line 4 is not recognised. That's not good, is it?
