How to enable/disable DKIM signing for all domains in Plesk for Linux
7 comments
    Fouad Ahmed Fouad
    Thanks, this solved it in no time!
    -1
    Vojkan Cvijanovic (Edited )
    3. Run the following command to enable DKIM signing for all domains:
    for domain in $(plesk db -Ne 'SELECT name FROM domains WHERE parentDomainId=0;'); do plesk bin domain_pref --update $domain -sign_outgoing_mail true; done
    This didn't work for me on CentOS 7 + Plesk 18.
    I get:
    -bash: syntax error near unexpected token `do'
    1
    Renan Genova Ferreira
    Hi, Vojkan Cvijanovic!
    The command should work there - please make sure you run it as root and that no extra characters are copied over.
    Thanks
    -1
    Emilio Ortiz
    If you have problems validanting DKIM records first disable all (false) and after enabled all (true).
    1
    Senaka
    I have executed the 3rd command with "false" and then run again with "true". But gmail saying my server domain email's DKIM is "FAIL". How to fix it please? Can we regenerate new Key domain domains?
    1
    Olivia Merinos (Edited )
    I executed the 3rd command and keep getting bash: plesk: command not found
    For the record, I am logged in as root, running Plesk Obsidian on Debian 10. I also tried to append the route to plesk /sbin/plesk on the variable with the same result, can someone assist on this? Thanks to anyone reading this!
    Philipp Lehmayr
    Does this DKIM signing overwrite any existing email headers? i.e. if I already send my email signed, will those headers be overwritten with a different value?
