How to enable/disable DKIM signing for all domains in Plesk for Linux
4 comments
    Fouad Ahmed Fouad
    Thanks, this solved it in no time!
    Vojkan Cvijanovic (Edited )
    3. Run the following command to enable DKIM signing for all domains:
    for domain in $(plesk db -Ne 'SELECT name FROM domains WHERE parentDomainId=0;'); do plesk bin domain_pref --update $domain -sign_outgoing_mail true; done
    This didn't work for me on CentOS 7 + Plesk 18.
    I get:
    -bash: syntax error near unexpected token `do'
    Renan Genova Ferreira
    Hi, Vojkan Cvijanovic!
    The command should work there - please make sure you run it as root and that no extra characters are copied over.
    Thanks
    Emilio Ortiz
    If you have problems validanting DKIM records first disable all (false) and after enabled all (true).
