Plesk for Windows
Plesk for Linux
kb: how-to
ext: le
ABT: Group A
- Plesk for Windows
Is it possible to secure webmail on domain without web hosting with an SSL certificate?
Yes, that is possible via the SSL It! extension. This possibility was introduced on version 1.4.0 from the extension.
It can be done as follows:
Make sure that the SSL It! extension is installed at Extensions menu > My Extensions > SSL It!:
- If it is not installed, go to Extensions > look for SSL It! > click Install.
- If it is installed, make sure that the extension is on version 1.4.0; if it is on an older version, go to Extensions > Updates > click Check Now > then select SSL It! and click Update to update the extension.
Go to Domains > example.com > SSL/TLS Certificates > Install > leave the option Secure webmail on this option enabled > click Get it free:
2 comments
Got version 1.7.2. It will not let me do it. Please advise.
Best Regards,
Jon F.
The host must be disabled otherwise plesk tries to certify the domain as well and returns an error
