How do backups to remote storage (FTP or cloud) work on a server with Plesk?
9 comments
    Jean-Luc (Edited )
    I have enable remote backup to a Google Drive server. This works fine but despite not having enabled "Server Storage" I can see that the backup folder is growing by the day. See print screen below. Why ?
    Lev Iurev
    Hello @Jean-Luc Sorry for the delayed answer, please let me your Plesk version from the 'plesk version' command output.
    Joe B (Edited )
    We are facing the same issue with Plesk for Linux, our /var/lib/psa/dumps ended up being over 400GB+. We use a remote FTP server, so why is it our local storage is filling up and not being deleted after sync?
    Server Info
    OS: CentOS 7
    Plesk: Onyx Version 17.8.11 Update #34
    Bulat Tsydenov
    Hello Joe,
    There can be several possible reasons:
    1. Upload to remote storage fails due to some reasons and you have "Save backups in the server storage if the upload to FTP fails" option enabled under Tools & Settings - Backup Manager - Settings.
    2. You have customers on the server who have permissions to create their own backups and they create backups on the local storage. You can find the customers and domains which occupy much disk space with help of this article Backup structure in Plesk for Linux
    B Pfleging (Edited )
    How does the explained procedure affect the traffic and actions on the remote storage? Given that for S3 storage you might be payed based on a) actions on the server b) the amount of incoming traffic (to the storage space) c) the amount of outgoing traffic (from the remote storage) and d) the amount of remote storage space. Can you perhaps give a concrete example (obviously with only estimated numbers)?
    Given that you seem to send separate files to the storage - how are they combined to one joint file at the remote side?
    Maybe you can also add this information to the manual (and link to this article from the manual)?
    Maxim Krasikov
    Hello @b_p,
    Please let me address your questions:
    • Inbound traffic on the remote storage equals to the size of the uploaded backups.
    • Outbound traffic is insignificant and is used for checking the structure of uploaded backups.
    • Consumed disk space equals to the size of the uploaded backups.
    • Files are compressed on the source server before uploading to the remote storage.
    • Files are uploaded into the singe archive during a durable procedure. Only one single action is performed.
    The article has been updated as well. Thank you for your remarks!
    @... Some more details might also be helpful on https://docs.plesk.com/en-US/obsidian/administrator-guide/backing-up-and-restoration/global-backup-settings.59265/. It should be explained over there (or on one of the subpages) how the backup process works and what to keep in mind regarding required disk space.
    For instance, my server (210 of 300 GB disk space is used, a full Plesk backup consumes 130 GB) stopped the backup today with the message "not enough disk space for your backup". I assume this was due to the fact that I set the option "start backup only if ... GB disk space available" to 80 GB. I lowered this to 70 GB now and probably need to check if that works out...?
    Nelson Leiva
    Hello B Pfleging,
    Thank you for the input. More details about the backup process can be found in the official Plesk documentation such as the one you have linked or the link found in the Additional Information section.
    The option you mentioned is designed to prevent Plesk backups from consuming all free disk space or prevent the backup from starting if there is not enough free space on the server. We have a guide which describes the same https://support.plesk.com/hc/en-us/articles/115000300985-How-to-prevent-Plesk-backups-to-consume-all-free-disk-space-
    Kurt Kokoruz
    I'm trying to find information on the security of the transfer process.
    I use the following plugins and am trying to understand when Plesk creates the backup and sends it to S3 what security measures are in place during the transfer.  Does it use SFTP?  Is it transferred over HTTPS?  If someone could please leave a comment and a link explaining the process I would appreciate it.
    https://www.plesk.com/extensions/s3-backup/
    https://www.plesk.com/extensions/offer-complete-backup-solution/
    https://docs.plesk.com/en-US/obsidian/customer-guide/backing-up-and-restoring-websites/configuring-remote-storage.78922/
    1
