kb: technical
Apache service goes down frequently
The following errors can be found in the Apache error log
/var/log/httpd/error_log
:CONFIG_TEXT: AH03262: mod_watchdog is required
AH00020: Configuration Failed, exiting -
The following errors can be found in the system log
/var/log/messages
:CONFIG_TEXT: systemd[1]: httpd.service: Reload operation timed out. Killing reload process.
Systemd[1]: httpd.service: Failed with result 'exit-code'.
The watchdog module is required for Apache to work, however it is disabled on the server
- Log into Plesk
- Go to Plesk > Tools & Settings > Apache Web Server
- Enable the watchdog Apache module
- Press OK
