Plesk Premium Antivirus does not detect infected emails.
Antivirus protection is enabled for an email account at Domains > example.com > jdoe@example.com > Antivirus.
The Plesk Premium Antivirus is shown as running at Tools & Settings > Services Management.
Mail filters are disabled/misconfigured in the Postfix configuration.
Open the file
/etc/postfix/main.cf
in a text editor. In this example, we are using the vi editor:# vi /etc/postfix/main.cf
Adjust the
smtpd_milters
andnon_smtpd_milters
(if exists) parameters the following way:Note: Make sure that these parameters are not commented with # at the beginning of the line.
CONFIG_TEXT: smtpd_milters = , inet:127.0.0.1:12768
non_smtpd_milters = -
Save the changes and close the file.
Verify the changes:
# grep -ir milters /etc/postfix/main.cf
Restart the postfix, pc-remote, drwebd services:
# service postfix restart
# service pc-remote restart
# service drwebd restart
3 comments
Just a quick comment: why is there a comma between the = and the milter services? Normally, the comma (or a space) serve as separator in a list of multiple milters (http://www.postfix.org/postconf.5.html#non_smtpd_milters, http://www.postfix.org/postconf.5.html#smtpd_milters). However, as there is only one, the comma does not really make sense?
Hello b_p,
You're right, without a comma it should also work fine.
The comma is just there in a default configuration.
Well, for a "clean" configuration, I would recommend to delete it!
