APS Catalog is unreachable: Connection timed out
Created:
2016-12-12 03:44:11 UTC
Modified:
2017-08-08 13:34:46 UTC
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
  • Plesk Onyx for Linux
  • Application Catalog is unreachable:
    APS Catalog error: Connection timed out after 30000 milliseconds
  • Unable to open Customize tab:
        Secure connection failed
The following error appears in /var/log/plesk/panel.log :
[2016-11-17 13:03:35] ERR [panel] APS Catalog error: connect() timed out!
[2016-11-17 13:03:35] INFO [apscatalog] Retrieving APS Catalog resource: http://catalog.marketplace.parallels.com/all-app.atom?obsolete=hide&pageSize=999999&order=%2Bname%2C-version
  • mtr utility shows big packets loss at an intermediary router:
     Keys:  Help   Display mode   Restart statistics   Order of fields   quit
    Packets Pings
    Host Loss% Last Avg Best Wrst StDev
    1. 1.2.3.4 0.0% 2.9 2.1 1.2 14.5 2.5
    2. 2.3.4.5 0.0% 6.3 3.7 2.3 23.4 3.4
    3. 3.4.5.6 0.0% 2.2 3.8 1.9 54.0 8.2
    4. 4.5.6.7 0.0% 2.2 2.5 2.0 4.2 0.4
    5. 5.6.7.8 10.0% 195.4 195.8 194.9 201.3 1.2
    6. 6.7.8.9 82.5% 191.4 191.7 191.4 192.6 0.5
    7. 7.8.9.1 0.0%
  • Application catalogue is unreachable:
The issue is caused by intermediary router. It makes connectivity between Plesk and catalog.marketplace.parallels.com server unstable.
Please contact your ISP or the company that owns these hosts (network routers) regarding this issue.
Additional info
Cannot install an application: APS Catalog error: couldn't connect to host
