Starting on October 19, 2021, we will enable single-sign-on for our Plesk Support Center to provide a seamless login/account experience. This implies that you’ll be able to use a single account across any of our web-facing properties.
To be prepared for this change and to avoid the need to register during your next ticket submission after the change, we encourage you to create an account here before October 19 using the same email address as your current Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account. You will continue to use ZenDesk authentication until we switch over to single-sign-on on October 19th.
Is it possible to upgrade system PHP in Plesk for Linux
12 comments
    Janet
    I have the same question and this response does not address it.   I use PHP 7 in my applications but when I try to load packages via the command line I get errors like:
    league/oauth2-client 2.3.0 requires php ^5.6|^7.0 -> your PHP version (5.4.45)
    5.4.45 is by OS Vendor and I need to know how to update this as it is what the Centos command line thinks my PHP version is.
    Alexandr Tumanov
    @Janet, use Plesk PHP in CLI instead of OS one:
    # /opt/plesk/php/7.2/bin/php -v
    PHP 7.2.3 (cli) (built: Mar 2 2018 14:04:04) ( NTS )
    1
    Phil Ainley
    I have a similar issue. I recently uploaded a new wordpress version of a website and it won't allow certain plugins because the server php is too old. It is currently running php 5.3.3
    How can it be updated without disryuption?
    I would have thought this kind of update would have been automated, or at least handled by yourselves like with most ISPs
    Thanks
    Ivan Postnikov
    Hello @Phil!
    A Wordpress instance installed on a domain does not use server PHP version, it uses domain PHP version. PHP version may be selected at Domains > example.com > PHP Settings. New PHP versions, which will be available to select need to be installed according to this article.
    Erwan
    @Janet, Avez-vous une cause nouvelles que j'ai le même problème que vous avez fait / fait? TIA.
    Alexandr Redikultsev
    Hi @Briand,
    Version of PHP selected at Domains > example.com > PHP Settings is actually not the same that is used in the command line.
    To use another PHP version via the command line, use the full path to it, see the following article for additional details: https://support.plesk.com/hc/en-us/articles/115003766853-How-to-specify-PHP-version-on-the-Plesk-server-for-command-line-command-php-for-user-
    2
    Erwan (Edited )
    Thx @Alexandr. I'm investigating the article you pointed at.
    Unknown User
    Thanks Alexandr,
    The article was very helpful for me!
    Eronar Diaras
    But!
    If my Plesk Server an old server (example with Onyx), but now I upgraded to Obsidian?
    So: Not Obsidian clear install. Ugraded to Obsidian with many long-running services (mail, domain, etc).
    This plesk services do not depend on system PHP, which makes it possible to upgrade system PHP to the next version????????
    julian bonpland mignaquy
    Hi Eronar Diaras, that is correct, if you are running Obsidian Plesk services do not depend on system PHP which makes possible to upgrade system PHP.
    Eronar Diaras
    How could I upgrade or replace the vendor php (5.4.16) in multiple php plesk system? (Plesk Obsidian)
    Current php in the Tools and Settings > PHP Settings (/admin/php-handler/list) are:
    - php 5.4.16 by OS vendor
    - php 5.6.40
    - php 7.1.33
    - php 7.4.3
    ssh #php -v:
    PHP 5.4.16 (cli) (built: Nov 1 2019 16:04:20)
    Pavel Rozental
    Hello,
    If PHP "php 5.4." is not needed for security reason you can disable it in Tools & Settings > PHP Settings and use only PHP provided by Plesk.
    In case of it's needed to update system PHP you should find and enable a repository that contains newer PHP version and update PHP, for example:
    https://linuxconfig.org/how-to-install-or-upgrade-to-php-7-on-centos-linux-server
