Filemanager not working
Created:
2016-12-12 03:40:46 UTC
Modified:
2017-08-08 13:45:40 UTC
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
  • Plesk Onyx for Linux
  • Plesk Multi Server
  • It is not possible to do changes to the configuration of nginx, like enabling SSL. There is no error shown in Plesk, but the changes not applied.
No config files created under /etc/nginx/plesk.conf.d/vhosts
DEBUG [util_exec] Command "nginx-config -l /var/www/vhosts/system/example.com/conf/nginx.conf:/etc/nginx/plesk.conf.d/vhosts/example.com.conf" is filtered out, response: array (
'stderr' => '',
'stdout' => '',
'code' => '',
  • Plesk file manager is not working. The following error message can be found in the panel.log :
    ERR [panel] Plesk PermissionDeniedException: Symbolic links outside the webspace are not allowed /: Access to realpath denied: /var/www/vhosts/example.com/
  • Plesk Multiserver Extension is present, but disabled.
  • Plesk database contains the following:
    plesk db " select * from misc where param='disable_provisioning'"
    +----------------------+-------+| param | val |+----------------------+-------+| disable_provisioning | true |+----------------------+-------+
Misconfiguration of Plesk Multiserver caused by database inconsistency.
  1. If Plesk Multiserver extension is disabled, update psa.misc table accordingly. Create backup of psa database first:
    plesk db dump > psa_backup.sqlplesk db "update misc set val='false' where param='disable_provisioning'"
Reconfigure affected domains
