FTP user is not able to access, upload or create lib or etc directories: Permission Denied
2 comments
    Unknown User
    I can understand that you prevend users from changing anything in /etc or /lib. But this should be the absolute and not the relative path.
    For example I could not create the relative folder /lib in the home directory of my ftp user, which would be absolute path /httpdocs/username/lib.
    Hopefully you can fix this issue?
    Ivan Postnikov
    @Hans
    Hello!
    On the test server I have successfully created the directory using the following command, being logged in as FTP user:
    mkdir -p ./httpdocs/username/lib
