DKIM does not work: DKIM verify result: DKIM verification failed: signature verification failed
7 comments
    Fahd
    I follow your steps, but after install the new DK sign and enabling Use DKIM spam protection system to sign outgoing email messages in mail server setting the http://dkimvalidator.com saying that my email does not contain a DKIM Signature. Why it happened like that. does the DK sign file has a problem?
    Jan van Leeuwen
    Hi
    the errors shown are
    db_check[12345]: DKIM verify result: DKIM Feed: No signature
    plesk sendmail[12345]: Canonname is not correct fqdn
    plesk sendmail[12345]: It is impossible to detect the FQDN of the host. Please make sure that the hostname is correctly specified in /etc/hosts and goes right after the host's IP address. Depending on your OS, you might need to set the host in /etc/HOSTNAME or /etc/hostname.
    there seems to be a problem with  etc/hosts and etc/hostname
    etc/hosts
    127.0.0.1 localhost.localdomain localhost
    127.0.0.1 rs123456
    # The following lines are desirable fpr IPv6 capable hosts
    ::1 localhost.localdomain localhost ip6-localhost ip6-loopback
    ff02::1 ip6-allnodes
    ff02::1 ip6-allrouters
    37.999.999.123 server.mydomainname.domains server
    hostname
    rs123456
    I guess "rs12345" must be changed in "server.mydomainname.domains"
    Since it is a vserver I will have to ask the Provider if that does not cause problems with them.
    Also it seems that magicspam cannot handle IPv6, is that a known problem?
    Regards,
    Jan
    Alex Werber
    There was the same problem with my project
    Ivan Postnikov
    Hello @Fahd!
    Please, let me know, what Plesk version do you use and OS version?
    Anton Maslov
    Hello Jan,
    That particular problem does not exist in 17.8, it was fixed in 17.0, however, the error itself is general and the reason might be in something else.
    I recommend to review /var/log/maillog for more details and try to search with additional symptoms.
    Jan van Leeuwen
    I have Plesk 17.8.11 on Ubuntu 14.04.
    Will this help to cure "DKIM-signature verification failed"?
    Regards,
    Jan
    Maxim Krasikov
    Hello @Jan van Leeuwen,
    If the solution with changing hostname is not helpful, please contact Plesk support for assistance:
    We don't have information about MagicSpam restrictions. I suggest contacting MagicSpam community or support available using the link below for assistance:
    https://www.magicspam.com/support.php
