- Plesk Onyx for Linux
After upgrade to Ubuntu 16.04 the following messages start appearing in mail queue:
# mailq
-Queue ID- --Size-- ----Arrival Time---- -Sender/Recipient-------
90EC33500755 2804 Thu Nov 3 16:10:24 MAILER-DAEMON
(Command died with signal 6: "/usr/lib/plesk-9.0/postfix-local". Command output: *** stack smashing detected ***: /usr/lib/plesk-9.0/postfix-local terminated)
test@example.tld
This is bug with ID
PPPM-5165
which is planned to be fixed in future Plesk updates. Mail SRS library could not change
from
into SRS format.
Workaround
Add the following parameter into the
/etc/postfix/main.cf
empty_address_recipient = MAILER-DAEMON@localhost.localdomain
