Plesk for Windows
Plesk for Linux
kb: technical
ABT: Group B
- Plesk for Windows
Subscriptions in Plesk > Subscriptions menu are marked with a red question mark despite the fact that resources are not exceeded.
An attempt to sync subscriptions with a Service plan fails:
PLESK_WARN: Unable to sync subscriptions with the service plan.
The Daily Maintenance task has not been executed yet so subscriptions' resource usages were not updated.
Perform one of the following:
Force execution of the Daily Maintenance script so the resource usage is updated manually.
Wait for the Daily Maintenance tasks to execute at a scheduled timeframe.
If after DailyMaintenance task the issue is not fixed, check the server for consistency (inconsistent records for subscriptions can cause the issue):
# plesk repair db -n
1 comment
Worked for me, thanks
