[How to] How to trigger notification send for particular events
Created:
2016-11-16 13:26:18 UTC
Modified:
2017-08-08 13:27:02 UTC
Have more questions?
Submit a request
  • Plesk 11.0 for Windows
  • Plesk 11.5 for Windows
Information
First of all check that notification for required event is enabled in Home -> Tools & Setting -> Notifications
notifications
Check if all required checkboxes are enabled. Also check if correct email addresses are specified in admin settings, resellers setting, customers settings.
Notifications for such events as:
  • "Resource usage limits exceeded by reseller account"
  • "Reseller account suspended due to resource overuse"
  • "Reseller's resource usage limits reached by reseller's subscriptions due to overselling"
are sent upon daily maintenance task is execution. On the step ' AnalyseClientStatistics '. So if you have the reseller who exceeded his resource limits to trigger notification send run the following command
"C:\\Program Files (x86)\\Parallels\\Plesk\\admin\\bin\\php.exe" -dauto_prepend_file= "C:\\Program Files (x86)\\Parallels\\Plesk\\admin\\plib\\DailyMaintainance\   ask-script.php" AnalyseClientStatistics "--period=daily" "--process-client-ids=$client_id"
where $client_id is ' id ' value of the reseller from clients table of psa database:
mysql> select * from clients \\G
  • "Resource usage limits exceeded by subscription"
  • "Subscription suspended due to resource overuse"
are sent when ' AnalyseDomainStatistics ' part of daily maintenance task is executed.
If you have a subscription that exceeded resource limits to trigger notification send run the following command:
"C:\\Program Files (x86)\\Parallels\\Plesk\\admin\\bin\\php.exe" -dauto_prepend_file= "C:\\Program Files (x86)\\Parallels\\Plesk\\admin\\plib\\DailyMaintainance\   ask-script.php" AnalyseDomainStatistics "--period=daily" "--process-domain-ids=$domain_id"
where $domain_id is 'id' value of the domain in domains table of psa database.
mysql> select * from domains \\G
