How to verify that SSL for IMAP/POP3/SMTP works and a proper certificate is installed?
Note: To change default certificates for IMAP/POP3/SMTP, visit this KB article.
Using online checkers
Check SSL using online tools:
- ImmuniWeb® SSLScan
- SSL Checker - SSL Certificate Verify
- SSL Server Test (Powered by Qualys SSL Labs)
Using a Linux server
Any Linux server can be used for these tests. If you do not have a Linux server, use the online checkers above.
To verify SSL, connect to any Linux server via SSH and use the instructions below:
IMAP via SSL uses port 993:
connect to a mail server using
openssl
:# openssl s_client -showcerts -connect mail.example.com:993
Check output and make sure that a valid certificate is shown:
CONFIG_TEXT: Server certificate
subject=/OU=Domain Control Validated/OU=PositiveSSL/CN=mail.example.com
issuer=/C=GB/ST=Greater Manchester/L=Salford/O=COMODO CA Limited/CN=PositiveSSL CA 2 -
Make sure that you received IMAP server response:
CONFIG_TEXT: * OK [CAPABILITY IMAP4rev1 UIDPLUS CHILDREN NAMESPACE THREAD=ORDEREDSUBJECT THREAD=REFERENCES SORT QUOTA AUTH=CRAM-MD5 AUTH=PLAIN IDLE ACL ACL2=UNION] Courier-IMAP ready. Copyright 1998-2004 Double Precision, Inc. See COPYING for distribution information.
POP3 via SSL uses port 995:
Connect to a mail server using
openssl
:# openssl s_client -showcerts -connect mail.example.com:995
Make sure that you received POP3 server response:
CONFIG_TEXT: +OK Hello there. <1793.1385684315@localhost.localdomain>
SMTP via SSL uses port 465:
openssl
:# openssl s_client -showcerts -connect mail.example.com:465
Make sure that you received SMTP server response:
CONFIG_TEXT: 220 mail.example.com ESMTP Postfix
SMTP via TLS/StartTLS uses port 587 (The submission port should be enabled in Plesk):
openssl
:# openssl s_client -starttls smtp -showcerts -connect mail.example.com:587
CONFIG_TEXT: 250 DSN
4 comments
I have similar problem, as OVH Let's encrypt SSL won't work, and mail certifies by domain always resort to ovh address.
@Henri, could you please describe the issue in more details?
@Lev Iurev
For starters I must say I'm very new to this and this is my first server setup with Plesk and mail server.
Would you recommend 1 serverwide certificate to secure multiple domains or every domain with own sertificate as my vps is with shared IP?
The problem is that I can't make sertificate now for my OVH vps cause number of *.ovh.net certs are restricted by Let's Encrypt. So should I get a own domain for vps and plesk server and get sertificate to that or could and should I get separate domain name sertificates to work with each domain? As for now the domains seems to show vps plesk self signed certificate even though they are set to Let's Encrypt via Plesk panel.
Is there a way to force certificates to domain and bypass the plesk certificate and check them after they are set that tey truly are correct? Do I just need some refresh? I have use something like for now:
@Henri Pelkonen,
I would use free Let's Encrypt certificates to secure my domains.
Make sure that SSL/TLS support is enabled and Let's Encrypt certificate is selected in Domains > example.com > Hosting Settings > Security
Afterwards, use the following command to check which cert is used for a domain (where example.com is the domain name):
