- Plesk for Windows
One of the following errors is displayed when trying to access the Web Presence Builder from Plesk either after a clean installation or after the upgrade from previous versions:
PLESK_INFO: Message SQLSTATE[42S02]: Base table or view not found: 1146 Table 'sitebuilder5.site_version' doesn't exist
File Generic.php
Line 32
Type SB_Facade_Exception_Generic
PLESK_INFO: A fatal error has occurred
SQLSTATE[42S22]: Column not found: 1054 Unknown column 'share_parents' in 'field list'
Details have been logged for the administrator.
Web Presence Builder database was not created during an installation or upgrade procedure because the MySQL strict mode is enabled.
Disable MySQL strict mode by modifying the MySQL configuration file in any text editor, for example, in the vi text editor.
WithdrawSTRICT_TRANS_TABLES
andSTRICT_ALL_TABLES
from thesql-mode
configuration directive or comment it out altogether:# cat /etc/mysql/my.cnf|grep sql-mode
#sql-mode="STRICT_TRANS_TABLES,NO_AUTO_CREATE_USER,NO_ENGINE_SUBSTITUTION" -
Restart MySQL service to apply changes
# service mysql restart || service mariadb restart || service mysqld restart
Recreate Web Presence Builder database
For clean installation:
# /usr/local/psa/bin/sw-engine-pleskrun /usr/local/sb/utils/configure.php --init_db --merge_config --db_admin_name=admin --db_admin_passwd=`cat /etc/psa/.psa.shadow` --sb_db_user_passwd=<random_password>
# /usr/local/psa/bin/sw-engine-pleskrun /usr/local/sb/utils/post_configure.php
For the upgrade from previous version:
Connect to the server via RDP.
Disable MySQL strict mode by modifying the MySQL configuration file:
Windows platform 32bit --
C:\Program Files\MySQL\MySQL 5.1 Server\my.ini
Windows platform 64bit --
C:\Program Files (x86)\MySQL\MySQL 5.1 Server\my.ini
For modern Plesk installations --
%plesk_dir%MySQL\my.ini
and%plesk_dir%Databases\MySQL\Data\my.ini
Withdraw
STRICT_TRANS_TABLES
from thesql-mode
configuration directive or comment it out altogether:CONFIG_TEXT: #sql-mode="STRICT_TRANS_TABLES,NO_AUTO_CREATE_USER,NO_ENGINE_SUBSTITUTION"
Restart MySQL to apply changes:
C:\> sc stop MySQL
sc start MySQLFor Modern Plesk installations use Plesk Services Monitor: select Plesk SQL Server and SQL server checkboxes, click on the Restart button.
Recreate Web Presence Builder database:
C:\> "%plesk_dir%\admin\bin\local_mysql_helper.exe" --create-database-and-user -database "sitebuilder5" -database-user "<DB_USER>" -database-user-password "<DB_USER_PASSWORD>"
C:\> "%plesk_dir%\admin\bin\php.exe" -c "%plesk_dir%\admin\php.ini" -dauto_prepend_file="" "%plesk_dir%\sb\utils\configure.php" --init_db --skip_database_creation --merge_config
C:\> "%plesk_dir%\admin\bin\php.exe" -c "%plesk_dir%\admin\php.ini" -dauto_prepend_file="" "%plesk_dir%\sb\utils\post_configure.php"
2 comments
In my case giving error with last 2.,3. command
C:\>"%plesk_dir%\admin\bin\php.exe" -c "%plesk_dir%\admin\php.ini" -dauto_prepen
n --merge_config
Warning: require_once(vendor/autoload.php): failed to open stream: No such file
or directory in C:\Program Files (x86)\Plesk\sb\include\init.php on line 4
Fatal error: require_once(): Failed opening required 'vendor/autoload.php' (incl
ude_path='C:\Program Files (x86)\Plesk\sb/include;.;C:\php\pear') in C:\Program
Hi, please create a ticket to us so our support team may check the issue.
