Error while accessing Parallels Web Presence Builder: "Base table or view not found"
Created:
2016-11-16 13:24:36 UTC
Modified:
2017-08-16 18:26:55 UTC
Have more questions?
Submit a request
  • Web Presence Builder for Linux
  • Plesk 11.x for Linux
  • Plesk 11.x for Windows
  • Plesk 12.0 for Windows
  • Plesk 12.0 for Linux
  • Plesk 12.5 for Windows
The following error is displayed when trying to access the Web Presence Builder, either after a clean installation or upgrade from previous versions:
Message SQLSTATE[42S02]: Base table or view not found: 1146 Table 'sitebuilder5.site_version' doesn't exist
File Generic.php
Line 32
Type SB_Facade_Exception_Generic
or
A fatal error has occurred
SQLSTATE[42S22]: Column not found: 1054 Unknown column 'share_parents' in 'field list'
Details have been logged for the administrator.
Web Presence Builder database was not created during an installation or upgrade procedure because the MySQL strict mode is enabled.
Disable strict mode in MySQL and recreate the Web Presence Builder database.
  1. Edit MySQL configuration file
    Linux platform -- /etc/mysql/my.cnf
    Windows platform 32bit -- C:\\Program Files\\MySQL\\MySQL 5.1 Server\\my.ini
    Windows platform 64bit -- C:\\Program Files (x86)\\MySQL\\MySQL 5.1 Server\\my.ini
    Withdraw STRICT_TRANS_TABLES and STRICT_ALL_TABLES from the sql-mode configuration directive or comment it out altogether:
    # cat /etc/mysql/my.cnf|grep sql-mode
    sql-mode="STRICT_TRANS_TABLES,NO_AUTO_CREATE_USER,NO_ENGINE_SUBSTITUTION"
  2. Restart MySQL service to apply changes
    Linux platform :
    /etc/init.d/mysqld restart
    Windows platform :
    > sc stop MySQL
    > sc start MySQL
  3. Recreate Parallels Web Presence Builder database
    Linux platform clean installation:
     # /usr/local/psa/bin/sw-engine-pleskrun /usr/local/sb/utils/configure.php --init_db --merge_config --db_admin_name=admin --db_admin_passwd=`cat /etc/psa/.psa.shadow` --sb_db_user_passwd=<random_password>
    # /usr/local/psa/bin/sw-engine-pleskrun /usr/local/sb/utils/post_configure.php
    Linux platform after upgrade from previous version:
    Windows platform :
    > "%plesk_dir%\\admin\\bin\\local_mysql_helper.exe" --create-database-and-user -database "sitebuilder5" -database-user "<DB_USER>" -database-user-password "<DB_USER_PASSWORD>"
    > "%plesk_dir%\\admin\\bin\\php.exe" -c "%plesk_dir%\\admin\\php.ini" -dauto_prepend_file="" "%plesk_dir%\\sb\\utils\\configure.php" --init_db --skip_database_creation --merge_config
    > "%plesk_dir%\\admin\\bin\\php.exe" -c "%plesk_dir%\\admin\\php.ini" -dauto_prepend_file="" "%plesk_dir%\\sb\\utils\\post_configure.php"
