Starting on October 19, 2021, we will enable single-sign-on for our Plesk Support Center to provide a seamless login/account experience. This implies that you’ll be able to use a single account across any of our web-facing properties.
To be prepared for this change and to avoid the need to register during your next ticket submission after the change, we encourage you to create an account here before October 19 using the same email address as your current Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account. You will continue to use ZenDesk authentication until we switch over to single-sign-on on October 19th.
Roundcube/Horde webmail and websites on FastCGI are not accessible: Connection reset by peer: mod_fcgid: error reading data from FastCGI server
6 comments
    Anna Morozyuk
    Hello @Apsides Communication,
    Alternatively, it might be caused by insufficient permissions for the /etc/passwd. Permissions should be set as in the example below:
    # ls -la /etc/passwd
    -rw-r--r-- 1 root root 3100 Feb 5 14:58 /etc/passwd
    If permissions differ, change it with the following command:
    # chmod 644 /etc/passwd
    If the error remains, contact support for the help: How to submit a request to Plesk support?
    Apsides Communication (Edited )
    Dear sir.
    I do all of this but my roundcube webmail continue with error 500.
    log :
    [Tue Feb 19 12:07:50.761225 2019] [fcgid:warn] [pid 23206:tid 140419207698176] (104)Connection reset by peer: [client xxx.xxx.xxx.xxx:35742] mod_fcgid: error reading data from FastCGI server
    [Tue Feb 19 12:07:50.761272 2019] [core:error] [pid 23206:tid 140419207698176] [client xxx.xxx.xxx.xxx:35742] End of script output before headers: index.php
    Can you help me ?
    BROU Charles
    thanks it worked for me!
    Anzhelika Khapaknysh
    As far as I know, you're already in touch with our Support Team. So I suggest continue the communication in the ticket.
    Alex (Edited )
    This problem arose after I decided to remove outdated php versions. 7.2 and 5 from os vendor.
    Re-installing them solved the issue.
    Edit:
    Roundcube uses PHP 7.2, so don't  remove it, even if you don't use it.
    Thanks for reply but issue is same.
