How to bulk reset passwords in Plesk
8 comments
    Ramakrishnan R
    How to Reset a specific domain users mail account passwords
    Example :
    # /usr/local/psa/bin/sw-engine-pleskrun plesk_password_changer.php `cat /etc/psa/.psa.shadow` '*****' --mydomain.com --users --mailaccounts
    is the above cmd Correct? any help
    Thank you
    Ramki
    -1
    Denis Bykov
    @Ramakrishnan R
    This script does not support domain selection and only intended to reset passwords globally.
    Instead, you may use the following command to list all mail accounts which belong to the domain example.com on Windows:
    > plesk bin mail -l | findstr example.com
    On Linux:
    # plesk bin mail -l | grep example.com
    And update passwords one by one using:
    plesk bin mail -u JDoe@example.com -passwd mypass
    Where 'mypass' is a new password.
    Panos Diotis
    how could we run and FTP password reset for specific domains?
    Daria Gavrilova
    Hello @Pdiotis,
    Thank you for your question.
    To change the password for FTP user, please check the following article: How to change FTP user password in Plesk?
    xrofran (Edited )
    Hola:
    Necesito un script que resetee las contraseñas de un dominio en concreto y me genere un csv?
    Podeis ayudarme?
    Saludos
  • Hola xrofran,
    Puedes preguntar por dicha funcionalidad a nuestro equipo de Professional Services aquí, que te lo harán bajo un coste ya que es una tarea administrativa.
    Alternativamente, puedes crearte tu propio script en base a nuestra documentación de linea de comandos:
    Un saludo
    Prodesignerch
    Hello, this script is not working for Plesk Obsidian. Any help?
    I got below error.
    [INFO] ==> Installed Plesk version/build: 18.0.25 CentOS 7 1800200325.19
    [2020-04-01 02:09:01][FATAL_ERROR] Unable to find Plesk 8.x, Plesk 9.x, Plesk 10.x or Plesk 12.x. Tool must be launched prior to upgrade to Parallels Panel 12.0.18 for the purpose of getting a report on potential problems with the upgrade.
  • Hi Prodesignerch,
    Then you used the wrong script. Please try with the Onyx one as stated in the article.
