Nmap error: Operation not permitted
Created:
2016-11-16 13:23:14 UTC
Modified:
2017-08-08 13:16:05 UTC
3
Have more questions?
Submit a request
  • Plesk 12.0 for Linux
The following error is shown while trying to check port using Nmap utility:
 Starting Nmap 6.40 ( http://nmap.org ) at 2016-02-04 21:25 GMT
sendto in send_ip_packet_sd: sendto(4, packet, 44, 0, 123.123.123.123, 16) => Operation not permitted
Offending packet: TCP 122.122.122.122:49291 > 123.123.123.123:5224 S ttl=37 id=29358 iplen=44 seq=453702184 win=1024
Offending packet: TCP 122.122.122.122:49292 > 123.123.123.123:5224 S ttl=46 id=38931 iplen=44 seq=453767721 win=1024
iptables misconfguration.
This issue usually occurs due to misconfigured iptables.
The following rules should be added to allow 'invalid' packages:
 iptables -A OUTPUT -m state --state NEW,ESTABLISHED,RELATED,INVALID -j ACCEPT
iptables -A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
2 Comments
  • 0
    Avatar
    Tommy Mairo
    While I have done these for iptables, but it not works.
  • 0
    Avatar
    Vitaly Zhidkov
    @Tommy, check if nmap works locally on your server, check other chains in iptables and check if there is any external firewall
