Plesk upgrade fails: Public key for package.rpm is not installed
Created:
2016-11-16 13:20:51 UTC
Modified:
2017-08-16 17:34:19 UTC
Have more questions?
Submit a request
  • Plesk 11.x for Linux
  • Plesk 12.0 for Linux
Upgrade to Plesk 12 fails with error:
atomic/gpgkey                                            | 1.3 kB     00:00
Fatal error during packages installation: Public key for php-odbc-5.4.29-35.el5.art.i386.rpm is not installed
YumBaseError: Public key for php-odbc-5.4.29-35.el5.art.i386.rpm is not installed
ERROR: Failed to run the Yum utility.
GPG validation for repository fails.
  1. Disable the GPG validation for repository that you use for downloading files (e.g. Atomic repo):
    # grep -i gpgcheck /etc/yum.repos.d/atomic.repo
    gpgcheck = 0
  2. Launch Plesk upgrade.
