- Plesk for Windows
Domain/subdomain/customer creation or migration fails with an similar errors:
PLESK_ERROR: Error: ProtDir_IIS::update() failed: Add Protected Directory failed: columns siteId, path are not unique
PLESK_ERROR: Error: ProtDir_IIS::update() failed: Add Protected Directory failed: Filename: Error: Cannot add duplicate collection entry of type 'add' with unique key attribute 'path' set to '/plesk-stat'
The database of protected directories has not been synchronized properly with Plesk.
Remove the failed domain via Plesk > Domains > example.com > Remove.
Connect to the server via RDP.
Synchronize the database of protected directories by executing the following command in
cmd.exe
:C:\> "%plesk_cli%\\repair.exe" --synchronize-protected-directories-storage
Go to Windows Start > All Programs and open Internet Information Service (IIS) Manager:
Go to the IIS > Sites tab and remove the example.com website.
Go to the IIS > Application Pools tab and remove the application pool of example.com, if it exists.
Go to Windows Start > All Programs and open MailEnable:
- Go to MailEnable > Messaging Manager > Post Offices and remove example.com, if it exists.
Re-create business object or re-run migration.
