Schedule Task is not executed on time: Task Scheduler did not launch task because instance of the same task is already running
Created:
2016-11-16 13:20:24 UTC
Modified:
2017-08-16 16:41:16 UTC
Have more questions?
Submit a request
  • Plesk 12.0 for Windows
  • Plesk 12.5 for Windows
  • Scheduled task to run PHP script stops executing after some time.
  • In Windows Task Scheduler this task is shown as Running .
  • On History tab for this task will be shown something like:
    Task Scheduler did not launch task "\\Plesk Scheduler Task #be23ba78c60597ea7122deea5a27313b"  because instance "{fb4661d8-4be8-48bc-a5e2-5da81333dcac}"  of the same task is already running.
  • %plesk_bin%\\runtask.exe process returns Non-existent process in Process Explorer.
  • disk usage is not updated
Internal issue with id #PPPM-3855 . It has been fixed in Plesk 12.5.
Consider an upgrade to Plesk 12.5 .
Workaround
If upgrade is not possible:
  1. Backup file %plesk_bin%\\plesksrv.exe .
  2. Stop Plesk Management Service ( plesksrv ).
  3. Download archive from attachment and unzip it.
  4. Copy patched file ( plesksrv.exe ) to %plesk_bin% directory .
  5. Start Plesk Management Service ( plesksrv ).
  6. Start Plesk PopPass Service ( PopPassD ).
  7. Restart task if needed from Windows Task Scheduler.
