Plesk update failed: proftpd-mod-vroot : Depends: proftpd-basic (>= 1.3.4~rc2-2~) but it is not going to be installed
Created:
2016-11-16 13:19:41 UTC
Modified:
2017-08-08 13:39:01 UTC
Have more questions?
Submit a request
  • Plesk for Linux
Plesk update/upgrade failed with failed dependencies error on Debian:
 The following packages have unmet dependencies:
Depends: proftpd-abi-1.3.4a
Package proftpd-mod-vroot is not compatible with psa-proftpd shipped with Plesk.
Remove incompatible package manually:
 # dpkg -r --force-depends proftpd-mod-vroot
Run Plesk autoinstaller and install all available updates or continue upgrade.
