High CPU usage for "sa-learn" and "spamtrain" processes
6 comments
    Robert Asilbekov
    @Alexander Bien
    Thank you for the feedback. The article has been updated.
    Peter Debik
    On CentOS
    echo "/bin/nice -19 /usr/bin/perl -T -w /usr/bin/sa-learn.orig $@" > /usr/bin/sa-learn
    must be executed as
    echo "/bin/nice -19 /usr/bin/perl -T -w /usr/bin/sa-learn.orig \$@" > /usr/bin/sa-learn
    because else, the "$@" will not be exported into /usr/bin/sa-learn.
    Ivan Postnikov
    Hello Bbennett
    Did you execute this command as a root user?
    The 60sa-update exists on my test server and the issue wasn't reproduced:
    # stat /etc/cron.daily/60sa-update
    File: '/etc/cron.daily/60sa-update'
    Size: 448 Blocks: 8 IO Block: 4096 regular file
    Device: 40f0b681h/1089517185d Inode: 409504 Links: 1
    Access: (0755/-rwxr-xr-x) Uid: ( 0/ root) Gid: ( 0/ root)
    Access: 2020-01-23 13:44:39.000000000 +0700
    Modify: 2020-01-23 13:44:39.000000000 +0700
    Change: 2020-01-27 20:52:40.452451535 +0700
    Birth: -
    # plesk -v
    Product version: Plesk Obsidian 18.0.23.1
    OS version: CentOS 7.5.1804 x86_64
    Alexander Bien
    Are you sure that we need to modify 60sa-update in order to change high cpu from sa-learn?
    This pstreelog output (C7, P17.8.x) would suggest otherwise:
    |-anacron---run-parts-+-50plesk-daily---sw-engine---sw-engine---spamtrain---su---sa-learn
    I couldnt find any mentioning of sa-learn in sa-update either. Please advise.
    Bbennett
    Trying to disable and get the error:
    mv /etc/cron.daily/60sa-update /root
    mv: cannot stat ‘/etc/cron.daily/60sa-update’: No such file or directory
    Anton Maslov
    Peter, article updated! Thank you for report!
