Websites are down: Problem loading page
Created:
2016-11-16 13:18:16 UTC
Modified:
2017-08-08 13:40:58 UTC
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
  • Plesk Onyx for Linux
  • Plesk 12.0 for Linux
Unable to access websites. The error is shown:
Previously, nginx was enabled on a server and apache is configured to listen 7080 , 7081 ports.
 # httpd -S | grep 7080| wc -l
It is down and it is not possible to start it:
/etc/init.d/nginx status
nginx is stopped
# /etc/init.d/nginx start
Not starting nginx as it is disabled in config
This command shows that nginx is enabled:
# /usr/local/psa/admin/bin/nginxmng -s
Enabled
Websites are switched to nginx , but it is disabled.
For CentOS, RedHat:
# cp -a /etc/sysconfig/nginx.rpmsave  /etc/sysconfig/nginx
For Debian, Ubuntu:
Edit /etc/default/nginx and set NGINX_ENABLED=yes
If steps above did not help, do the following:
  1. Disable nginx proxy using this command:
        # /usr/local/psa/admin/bin/nginxmng -d
  2. Enable it back:
        # /usr/local/psa/admin/bin/nginxmng -e
  3. Make sure that it is running:
        # /etc/init.d/nginx status
    nginx (pid 4135) is running...
